- When defining snap area size there should be option to use % not only pixels. For example 25% inputed in Y field will mean 25% of size. Such definition allows to make elastic snap areas independent of screen resolution.
- Follow display part option can be useful too. If activated, then snap area will put window next to part of screen user will go. Such option will allow, for example, to create 1 snap area for 1/4 of display size which can be used to 6 different snaps: upper-left 1/4, upper-center 1/4, upper-right 1/4 and so on
- There is lack of vertical justification of snap area text
- Automatic guide lines when moving and sizing snap area name field will allow to easier positioning when user have bigger number of snap areas defined
