Snap or resize with dual monitors
I have two identical 24" monitors side-by-side.
I'm trying to set up a 3-finger tap trigger that shifts a window to the side of current monitor that window is on.
This works for the preset basics (i.e. window resize left two-thirds, window resize left half), but I can't get it to work for my custom window size, which is closer to 3/4 of the screen on left or right. I've tried a snap area and custom resize, but those both appear to be monitor-specific, so my second monitor sends the window over to the first monitor instead of itself.
Is there a way to have the same 3 finger tap do the same resize action, only on the monitor where the cursor is?
