Snap Areas Span multi monitor
This might be a bug, or it might be a feature request. Not sure, so I apologize if this is in the wrong section. I was trying to create a custom snap area to resize an app to mostly fill and span across my two 4k monitors. It recognizes the window is past the single monitor and goes a little into the second but won't go all the way. Any way to get around this? Attached is a screenshot
  • Type of Mac:M3 Max Macbook Pro - 3 physical monitors - Two 21:9 ultrawides and 1 32:9 super ultrawide that is connected via two inputs giving the mac two 4k monitors side by side instead of one giant monitor.
  • macOS version: Version 14.5 (23F79)
  • BetterTouchTool version: 4.575
