Snap areas not working (6.931)
I've only been using bettertouchtool for the snap areas feature. It's been a few days that it doesn't work. "Edit snap areas" show nothing. I can create one but it won't work, as if none is there. I can see them in "Manage snap areas", they just dont work. Dragging window in the hot spot does nothing.
Latest version 6.931 (no newer alpha either atm).
Restarted.
Tahoe 26.4.1 on a M2 Max mbp pro.
Any ideas? is it a know bug?
if "Edit Snap Areas" doesn't show any, it means BTT can not find snap areas for your current display. Did something about your display setup change recently?
Could you post a screenshot of what you seen in the snap area manager?
the snap areas are there, they just dont work. Ive kept only one here, check screenshot.
Doesn't work. No changes in monitors for years
Is you BTT maybe disabled? (If you only use it for snap areas you wouldn't notice other things failing as well)
nope, it's active. If I enable some other feature (eg a mouse button action) it works OK
could you go to Help => Export Basic Debug Logs and send them to me ? (andreas@folivora.ai) they should show what is happening!
possibly a change from October 12 was a little too optimistic, I believe it could lead to weird race issues if two or more monitors of the exact same type are connected. If this is the issue you are encountering it should be resolved in 6.932 (uploading now)
6.932 didn't fix anything.
However, some of the next ones did, as I just updated to 6.948 and issue is resolved.
Thanks @Andreas_Hegenberg
I have the same exact issue with BetterSnaptool on Tahoe 26.6.2 M5 Pro. No changes to the Monitor Setup, no installations, nothing. Over night, the Snap Areas were not showing up anymore, although all can still be found in the Snap Manager. Even deletion of all of them and creating a new area does not fix it.
@michael.theissen try updating to 1.10.2, it is already on the app store but the auto update might not yet have run
Thanks, 1.10.2 fixed it!
