I have 2 screens connected to my computer, this had all worked fine before, it's been a few months since I've used this computer much. But when I make a snap area on one screen, it appears on the second screen. If I use the snap area on screen one, the window snaps to screen 1 as expected. If I use the snap area (that was auto duplicated) on screen 2 it snaps to screen one. If I make a new snap area on screen 2, it will also appear on screen one, and I get the same behaviour described above, the window will only snap to screen 1, even if the window I'd used to generate the snap area was on screen 2. It's like BTT can't distinguish between the two displays. But the expansion rectangle that shows the area the window will occupy appears on the same screen the snap area is on, even though it then snaps the window to the other screen. The affected screens are both the same type.
I have not tried the alpha version as this is a production computer and I'm in the middle of a big job with a tight deadline, so no alpha or beta or updating anything on here for the time being.
macOS 11.6.8
BTT 4.073 (2289)
- Type of Mac:
- macOS version:
