Snap areas are no longer displaying when using Move window modifier keys
Snap areas no longer show when using the move window modifier keys. I've even added new snap areas without using the any modifier keys, but same issue happens.
If I use the modifier keys + left click on the mouse, it works fine. This just recently noticed this issue today.
I have a Mac M2 that has this issue with 3 external monitors. I have a Mac Pro M3 and it works with just the modifier keys, no issues.
I have used the last release and even have tried the latest alpha. Not quite sure how to fix this (maybe some setting in MacOS?).
I've restarted, toggled settings. Disabled other applications from starting, wonder if anyone else has run into this problem.
Same here, I found a walk-around for now, If you move a window from the top bar (without modifier) and you press the snap area modifier the snap areas will show again, but moving windows with modified was the whole purpose for me
thanks for reporting, I'll have a look!
should be resolved in 4.854 alpha, uploading now!
Tested the alpha build and it appears to be fixed! Thanks for the quick turn-around.
Very minor, but it doesnt show the snap areas on my external monitors until I move the window to it. Not a big deal but just something I noticed was different than before.
Thanks again!
You are fast!, 4.854 works, thank you
