When using notch bar with full screen window on Ventura, unable to see smaller window and close button (red and green circle button) when mouse cursor is on top of screen. If I disable notch bar, I see them as screenshot.
Issue is circle buttons in screenshot is not visible when window is full screen with notch bar running
- Type of Mac:Macbook M1 Max
- macOS version: Ventura
- BetterTouchTool version: (please post the exact version - not just "the latest one") 3.914
