Small layout issue
Hallo Andreas,
the title bar is not alined. Not sure, maybe when using "size to fit" ?
for Ableton Live:
Live FavMenu.bttpresetzip (4.6 MB)
  • BetterTouchTool version: 5.524
it does seem to render correctly here (after importing your preset)
Is it always showing like this for you or after some interaction?
Strange...
I got it now alined,
by allowing "manual resize" and save "menu size" in the menu context menu.
you might can reproduce that issue:
if you use those settings, some "extra space" is added at the bottom:
and if you change then to "Fit content" the "extra space" is under the title bar...
Thx,
Christian
