Go to Using Java Script · GitBook. Under "2) Running Shell Scripts" you say this in a comment in the code sample:
this will execute the Apple Script and store the result in the result variable.
Instead of "Apple Script" (which is always spelled "AppleScript", BTW, so that needs to be updated everywhere), you mean "shell script".
Scott
