I am experiencing some UI sluggishness with BTT enabled that affects only my USB mouse but not my Magic Trackpad 2. With BTT disabled, the sluggishness does not manifest.
A couple of examples:
First, when gliding up and down a menu for any app, the highlight is slow to catch up with the mouse pointer, and some highlights are skipped. With BTT disabled, the highlight follows the pointer effortlessly and smoothly.
Video with BTT disabled: https://imgur.com/a/Li3oADn
Video with BTT enabled: https://imgur.com/a/kOHhGPJ
Second, moving a window around the desktop is similarly slow and jumpy. The window does not glide around smoothly with the mouse. With BTT disabled, the window moves around effortlessly.
The result is the same with or without the priority helper tool.
Other actions involving the mouse are similarly affected (e.g. selecting icons on the desktop).
Magic Trackpad 2 does not exhibit the problem.
Are they any settings that would specifically affect / conflict with only the mouse?
USB Mouse
Magic Trackpad 2 is fine
- Type of Mac: iMac17,1
- macOS version: 10.15.2
- BetterTouchTool version: 3.262 (1439)
