Double taps are available for two and three fingers on the Magic Mouse and two/three/four fingers on the trackpad, but not for one finger. Is there a technical reason for this? Otherwise, "single-finger double tap" gestures would be very useful—like the existing "single-finger tap" gestures (right/middle/left for Magic Mouse etc.), just double. ;-]
Why is there no reply to this? I too want a single double-tap. I could have sworn there used to be one. I want to use it to "roll up" windows with WindowMizer, ala Windowshade from back in the day.
@Andreas_Hegenberg: Is there a technical reason why we don't have these simple and rather obvious gestures? If not, any chance you could implement them?
Yes, I do want to revive it, pl forgive me if this feature has been added meanwhile—I cannot find it in the UI (but I admit that I may have missed it—it’s a lot to learn).
Anyway, it would be enormously helpful if I could add one-finger double/triple taps left and right.
IF this feature has been added meanwhile, I’d be thankful if any of you would point me to it.
Hasn't been added. Still seems to me this should be possible, given that all the single-tap gestures for multiple fingers are already there and even having both single- and double-tap at the same time seems to work fine.
I'd still find a single-finger double tap immensely useful, especially for the Magic Mouse where space is limited and a single-finger single tap is often triggered accidentally.
I just purchased BTT, and am hoping for this functionality to be added. Especially a "double tap left" and "double tap right" on the magic mouse, instead of just the single tap options. The single tap is useful but is accidentally activated too easily.
Piling on, yes, one-finger double, triple taps, and all permutations on all devices.
I'm guessing there's a technical issue here, given how extensively @Andreas_Hegenberg has developed gestures for this app and how apparent this gesture is. Still, it's puzzling not to hear anything on this for 4+ years...
@Anton_Staroverov it sounds like you just want tap to click on the mouse? BTT supports that, you need to assign left click to the single finger tap left gesture. It also supports double-clicks by double-tapping when configured like this.
I just bought a lifetime license and am quite disappointed that a basic feature like 1 finger double tapping is not possible.
Any news on this? Is it technically impossible or will it be implemented in the future?
there’s an app where i want to cancel the magic mouse double tap for it (since i accidentally activate it here and there), and i don’t see this trigger in BTT.
