Side Screen Is Causing Problems
@Andreas_Hegenberg Unfortunately, the BTT Side Screen doesn't seem to be working properly for me. Windows are added “on their own.” And the arrangement of my screens, as well as their resolutions, usually changes when the Mac wakes up.
How can I remove Side Screen?
delete the side screen action and restart BTT :slight_smile:
BTT tries to arrange the side screen in a way that is not accidentally reachable by mouse (you can adjust manually via the arrange button in system settings)
Thanks.
Yeah. But every time I wake up the Mac? Maybe it's just me, or maybe it's my settings. But the screens keep shifting around.
I also posted this issue recently, I had resolution problems.
I think you should take a look at this, Andreas. The side screen is a fantastic feature, but it’s also causing unintended side effects for more than one user.
I improved screen persistence in 6.1150, this might resolve most of these issues! (But needs to be tested with more screen setups)
For now, I can say it seems to have improved. But I need more time to test it.
The layout of the screens is still slightly off.
Side Screen changes it like this:
And here's how I'd like it to look:
The resolution and the main screen no longer seem to change.
Does that help?
If an open app has only one window, and that window is in the Side Screen, then the Side Screen should open when that window is selected using the BTT app/Window Switcher. No?
yep, makes sense! (clicking the Dock icon of the app should already open the side screen in this case)
One more thing: Maybe this is asking too much :slight_smile: I'll just say it anyway. When the side screen is full of windows, it would be great if those windows were restored after restarting BTT.
After all, BTT has to be restarted quite often, for updates and things like that.
Edit: Also: In case the difference between my screenshots isn't clear, it's quite significant. In the first case, I can't move the mouse (on the right) straight down to access the small screen.
