I had my system default touch-bar when my mac in on login screen, this allows me to use touchId to login. But after BTT 2.641 update, my mac shows BTT touch bar when I logout. Is it a bug or there is setting to fix it?
Touch id will still work, it is not affected by what the Touch Bar is showing!
hmm... the problem is the touchId doesn't work
