When I press the key combination assigned to "show control center" (mac default fn+c), instead of the control center, the "battery" item in the menubar opens. I think this behavior started after updating OS to 14.3, but not 100% sure.
Keyboard configuration (with any hardware)
- Type of Mac: M2 MBA
- macOS version: 14.3
- BetterTouchTool version: 4.075 (2291)
