Shortcuts not triggering
Hey.
I see that now more than ever shortcut in BTT doesn't trigger until I open the app and minimize it again.
Not sure if you guys are working already on it after the latest Mac Updates
Is there a way to correct or fix this behavior?
Please let me know
unfortunately there are no known issues like that (otherwise it would of course be high priority to fix). Many thousands of users are using the latest BTT on the latest macOS without problems.
So most likely the issue is related to some configuration. Are you sure your BetterTouchTool is enabled? What kind of actions are you using?
