jerl
1
Hi.
The Shortcuts-Menu action only works if there's no folder provided (empty text field -> all folders are shown).
If you provide a folder name, nothing is shown. It does not matter if the input is terminated by a line feed or not.
BTT 6.859, Golden Gate 27.2 Beta (26B5091g)
Thanks,
Jens
Seems to work fine here, are you shortcuts folders showing in BTT's action selector popover at the bottom? Or are they missing there as well?
jerl
3
The folders are missing as well.
All Shortcuts are there, but at the root level, not sorted into their folders, no disclosure triangles.
could you try with the latest BTT build? I made some small changes for Golden Gate yesterday.
jerl
5
Works! (BTT 6.860)
Both in the menu and in the action selector as well.
