Shortcuts Issue
I'm on BTT 6,379 and Sequoia 15.7.5
I have 2 triggers with the shortcut "⌃⌥⌘+Space"
Pressing it ess than 0,3 seconds executes an applescript and sends the same shortcut "⌃⌥⌘+Space" for opening Alfred search bar
Pressing it more than 0,31 seconds sends the shortcut "⇧⌃⌥⌘+Space" for opening the Alfred's clipboard
These two triggers has been working perferctly for years until yesterday.
Now the behaviour is this one:
As you can see, I press and hold the shortcut, the alfred's clipboard is shown for some tenths of second but the alfred search bar replaces it inmediately
Attached the two triggers:
exported_triggers.bttpreset (5.8 KB)
thanks should be resolved in 6.380 (was related to Advanced Triggers - Pass through keyboard shortcut if conditions not met - #8 by Andreas_Hegenberg )
(will be available in 10 min)
Fixed! Thanks!
