when waking up from sleep, keyboard shortcuts don't work anymore until I switch app (cmd+tab) at least once
I think this started around the time I installed the "process priority tool" (I enabled this option when you released version 3.182 (August, 20, 2019) that namely said the following :
" ** BTT does not need to restart after sleep anymore! - If you encounter any issues after sleep, please let me know.*"
..so maybe this has to do with either the helper tool or that update
keyboard
- Type of Mac: MacBook Pro (Retina, 13-inch, Early 2015)
- macOS version: 10.14.6 (18G95)
- BetterTouchTool version: 3.186 (1365)
pressing cmd+tab enabled the shortcuts again - however that's a bit annoying having to do that each time the macbook resumes from sleep
