Define a keyboard shortcut that sends a control sequence. E.g., define shortcut for fn*P that sends ^a. When triggered, the sent sequence is ordered incorrectly: {a down} {a up} {control down} {control up}. The control down should be first, the control up should be last.
I confirmed this broken order using VNC to an X server and running xev to see the events.
MacBook keyboard.
- Type of Mac: Macbook Pro with touch bar
- macOS version: 10.13.4
- BetterTouchTool version:
