Hello,
I had a shortcut for Forward Delete using the Del key on my external keyboard for several years, and generally love the software.
A couple of weeks ago it stopped working as usual, and instead only deletes if holding down the Del key (at which points and forward deletes until releasing the key).
When checking the box for "Show when shortcut is triggered", it appears that the shortcut is triggered on press and not only hold, but the delete action doesn't happen.
I tried updating BTT, relaunching, restarting my Mac, deleting the shortcut and creating it from scratch. So far nothing seems to resolve it.
Any ideas? Thanks in advance!
External keyboard (tried several ones including BT and wired)
- Type of Mac: Macbook Pro (M1) 2021 16-inch
- macOS version: Sonoma 14.6.1
- BetterTouchTool version: 4.664 (46640)
