Would it be possible to achieve with a single shortcut to have the current window centered 2/3?
At the moment I can achieve that only with a sequence of 2 shortcut and it's a pity because it's the most common view that I use.
This is only possible with BetterTouchTool though. @grebonato is using BetterSnapTool.
@grebonato, with BetterSnapTool the only way would be to set up a custom snap area for every monitor you use. However you can get a free 1 year license for my other app, BetterTouchTool. (Just download it and select the "BetterSnapTool" registration option)
