Hi and greetings from Italy.
I'm trying this app and first problem got out.
I assigned double tap with two finger for Shift ... and it works.
But Shift remain always on.
How can I deactivate the command?
Thank in advance
Are you using the "Shift Key Down" action? If so, the "shift key up" action will release it again.
Thank you very much. But can I tap again with two finger for shift key up?
try this
thank you very much.
I don't know how assigning an action and the cycle at the same trigger double tap two fingers
It should work like this.
select the trigger. In your case double tap...
select the "Cycle" action
click on "Configure"
select the "shift down" action
repeat this with "shift up"
Now your trigger will alternately trigger one or the other action. In any case, it should work like this.
E tanti saluti dall'estero al mio paese d'origine, che purtroppo non vedo da molto tempo.
Ciao Franco e grazie. Non ho avuto il tempo di provare per imprevisti sopraggiunti. Appena posso ti farò sapere.
Dove vivi e quali sono le tue origini?
Io vivo a Catania.
Ciao Non troppi dettagli... I miei sono cresciuti "nel tacco", se si capisce. Io vivo molto, molto più a nord... mi piacerebbe visitare la Sicilia, ma non ci sono mai stato ... se ciò che si vuole fare non funziona, fatti sentire.
Ciao. Purtroppo ho provato ma non ho capito come funziona il Cycle.
Se assegno Shift down e poi Shift up
esegue entrambi e quindi mi trovo sempre in shift up.
I can't using Cycle option. When I assign a mouse action an plus another mouse action, the trigger gets both commands so I'm always in the second one. Shift down then shift up = shift up.
Help me, please.
No answers?
I think I don't understand. What do you mean by the trigger gets both commands? Could you post a screenshot of how you set it up?
this is just n action sequence which will activate both actions in sequence:-) you need to use the „cycle through multiple actions“ action
Try this:
- Delete "shift key up"
- Add a second line with the + under "Action Sequence in Cycle Through"
- This is where "shift key up" belongs.
Grazie Franco. Questa è proprio la soluzione che cercavo. Chissà quante cose mi sfuggono di questo meraviglioso programma. Sai se c'è un Manuale dettagliato, in Inglese?
Thank you very much. This is the Solution. Just the way I was searching. Do you know if there is a detailed User Manual Guide?
Sono lieto che ora funzioni . Sì, esiste un manuale che copre i punti più importanti.
Ancora grazie!
