Shell Script Widget out of order
The widget reinitialises non stop. Check the video for more.
Touch Bar
  • Type of Mac: MacBookPro15,1
  • macOS version: 10.14.6 PB
  • BetterTouchTool version: 3.066
xxx
Fun Fact: The widget remembers the code somewhere, it actually works on the Touch Bar (more or less at least, idk if my code or the widget messes up… If I try to display my reminders with this script
/usr/local/bin/icalBuddy -npn -nc -ps "|
|" -po "datetime,title" tasksDueBefore:today+2
it displays everything correctly but the time, which is 3h early.)
Weird could you paste the complete widget here?
My shell script widgets seem to save fine.
Sorry for the delay. Here you go:
https://share.folivora.ai/sharedPreset/31968e41-2261-4679-aa71-4e844ccb345c
Funny enough, with the latest update it still doesn't work - but now I can create widgets that do, so this helps :wink:
Ah very weird display bug. Fixed in v3.070 (will be online in about 10 minutes)
