You can see that the icon color here is white, but it's still showing Black in BTT Setting and in the streamdeck..
- Type of Mac: MBP M1 Pro
- macOS version: 14.5
- BetterTouchTool version: 4.581
Thanks for reporting, I'll fix that. I think it will kind of work if you change the symbol style to hierarchical
Sounds good, Thaanks!
It works only if the icon in BetterTouchTool shows on the button.
when I change it in the Elgato Software to something else, it just stops working [Although I have the identifier setup, and it was working before changing the icon...]
I‘m not sure I understand, what did you change in the Elgato app?
Btw. turned out this is „just“ a display issue. The color option should be hidden if monochrome is selected
I changed the icon in the Elgato app and it stopped working.
It was working fine when it was showing the icon from BTT.
Got it!
I changed it to Hierarchical and it the color works now ![]()
weird, it shouldn’t even show an option to change the icon in the elgato software, that needs to be configured in BTT. I’ll check!
Oooh okay!
So I shouldn't change the icon in Elgato ![]()
