Severe typing lag and dropped keystrokes with BetterTouchTool / macOS text monitoring enabled
Problem description:
For about two weeks now, I’ve been experiencing a major issue with text input on my Mac whenever BetterTouchTool is active or macOS text monitoring is enabled.
The behavior is:
  • Noticeable lag while typing
  • Some keystrokes are not registered (characters get “swallowed”)
  • I have to type very slowly and deliberately for input to be recognized correctly
Key observation:
  • As soon as I quit BetterTouchTool or disable text monitoring in macOS, typing returns to normal with no lag or missed input.
Current assumption:
This seems to be either:
  • a configuration issue I might be missing
    or
  • a bug in BetterTouchTool or its interaction with macOS text monitoring
Questions:
  • Has anyone experienced similar behavior?
  • Are there specific BetterTouchTool settings that could cause this?
  • Is this a known issue/bug?
  • Are there any workarounds that don’t require disabling text monitoring completely?
System info:
  • macOS version: 26.4.1
  • BetterTouchTool version: 6.440
  • Device: MacBook Pro M3 Max
This usually means that some process on your system is using a very high amount of CPU (> 100%). Can you check via Activity Monitor?
