Hi there!
I want to set up "Move Window to Next Monitor" to work with both Control/Option/Shift Left Arrow (and Right Arrow). That way I don't need to think about which monitor the window ends up on, just that it moves to the other monitor. Is this possible?
Thanks, Craig
Yes. Just create 2 separate triggers, both with the same action.
Thanks for the reply! That did not work for me for some reason. But I found a work around.
Hmm weird.. I guess I'm not sure what you were asking then..
Trigger 1: Control/Option/Shift Left Arrow > Move Window to Next Monitor Trigger 2: Control/Option/Shift Right Arrow > Move Window to Next Monitor
should get you the same end result I confused now lol
