Set Trigger to Double Click
I would like to Trigger a Macro in a specific App with a Mouse or Trackpad DOUBLE Click. Ist this possible, and if, how can I configure it?
-> Example: Double Click in App, triggers a Keyboard Shortcut.
Thanks. :slight_smile:
You can configure that in the "normal mouse" section in BTT (standard clicks on trackpad can be configured there as well)
yes that is possible but I'm not an expert with KM. @Frank1 maybe you can tell how to do this :slight_smile:
//edit: seems like this is resolved :wink:
how do we do this though? I want double clicking the middle mouse button to do CMD + Tab but i cant see how to set it to double clicking instead of a single click
Basically you need to double-click the recording field
im trying to do that by double clicking with the middle mouse button but it doesn't work. I'm on version 3.402
this feature was added in a much later version (3.402 is 4.5 years old)
oh is there anyway to trick this into working without buying the upgrade?
