Set different values for Scroll Repeat Delay
Hi fellow BTT users,
I have created multiple different triggers that activate when using the scroll wheel of a normal mouse (they work in different apps).
The issue is that some of these would require different values to be set for Scroll Repeat Delay to function properly.
It seems however that if I change the value for one of the triggers, the value is also changed for all others.
Am I missing something, or is this perhaps a missing feature?
Many thanks to anyone who can help :slight_smile:
This is a limitation on how scroll triggers work.
Currently you'd need to use some scripting to get around that limitation. However improving the scroll features of BTT is high on my TODO list, so there might be some updates on this soon.
Many thanks, Andreas, looking forward!
For now, this might help:
