Sequoia window snapping animation not working with BTT
Excited to see that the new Sequoia tile dragging animation would be implemented in BTT (as I understood it). However it doesn't work for me, the animation is still as un-smooth as before. Any ideas of what might be the issue? I have "Integrate With Native System Resizing" enabled and haven't fiddled too much with the BTT settings.
For me, the animation looks rather smooth, but I noticed you have to disable a setting on in Desktop & Dock, which is differently named than what the instructions say. The name of this setting has probably changed in between beta versions of macOS.
ah thanks, I‘ll update the text!
