Im trying to send “CMD + >” to Spotify from anywhere using the F15 key.
But I can’t find the “Send to app” setting anywhere. It’s just not there.
Im using 26.3 Tahoe on a M1 Mac. App version 6.194
Thanks in advance!
Thanks in advance!
Thanks!! its finally working. I was searching in the wrong location.
It’s still not working fine. I was able to set up F13 for “CMD + ←” And F15 for “CMD + →” but F14 for “Space” is not working. Only when the app is open it will work. Even with the options “Bring app to front before sending”.
Any ideas?
It was working before I did an reinstall of my macOS.
What app are you trying it with?
Spotify
For spotify it is much better to use some simple Apple Scripts to control it (they removed support for background keyboard shortcuts a few years ago)
For example this apple script would play/pause:
tell application "Spotify"
if player state is playing then
pause
else
play
end if
end tell
Thanks! its working now! ![]()
