I am using BTT to add a remote control feature with Siri remote to my application. I've created preset with different Shortcuts that are sent to my app. For some reason, after installing BTT and my app on a new machine and importing presets the shortcuts are not working.
Siri Remote, Mac Mini
- Type of Mac: Mac Mini 2018, MacBook Pro 2016
- macOS version: 10.14.5
- BetterTouchTool version: 3.153 (1323)
I've repeated this procedure on ~10 mac mini recently and will do 2 more in a few days, so I will appreciate if you will guide me in collecting more information.
To work around this I have to manually open each Trigger, Action and re-select my App as a target application. Also if I enable HUD for the triggers before applying the workaround, BTT shows the HUD, but does not pass the shortcut.
