Sending keyboard shortcuts to some websites doesn't work depending on the modifier. For example, on Outlook web, if you cursor over a misspelled word, you can press option-down to bring up the spelling suggestions. And if you press this key combo on the keyboard, it works great. But if you assign this as an action to a trackpad trigger or stream deck button, the default behavior (go to end of the line) is performed.
MackBook Trackpad & Stream Deck tested.
- Type of Mac: MacBook Pro (16-inch, 2021)
- macOS version: 12.5 (21G72)
- BetterTouchTool version: 3.821
I've tried this with the
- send key down and key up
- send key down only
- send key up only
options and none seem to make a difference.
Testing on a site like Yet another keyboard tester does indeed show that the option-down keys are being sent.
