Send Data to Generic Device with specific wValue and wIndex
Hi
Thanks for your awesome tool for managing generic USB device. I use it for my Roccat Leadr mice.
I need to initialise this mouse before I can catch the correct USBHID input.
I try to use it with the GUI option and the bttSendDataToDevice function.
I catch with wireshark that, BTT trying to send hex data with the 0x0000, 0x0001, 0x0003 wIndex and wValue is 0x02##, where ## predefined by first byte of hex data, but I think you know it.
I need to specify the wValue, because I need to use 0x03## for sending with 0x0000 wIndex.
Can you make some options for bttSendDataToDevice function to set wIndex and wValue?
I attached my preset for Roccat Leadr Stand with some comment for the clear understrand.
Roccat Leadr Stand-Generic Send.bttpreset (11.2 KB)
Thanks for your help!
Gábor
Sorry for my ignorance...
If I use BTTActionSendDataReportType with value 2, BTT send the data with 0x03##.
