I've been getting the "Secure input activated" message really often recently. I am using a Mac with Chrome and have lots of tabs open. We use Google SSO at work, so there is probably a passkey dialog open somewhere amongst my multiple browser sessions and hundreds of tabs. Unfortunately the PID info isn't specific enough to locate the offending Window and tab. Is there any more you can do, as the PID invariably points just to 'Google Chrome'.
Ive tried the osascript -e 'tell application "BetterTouchTool" to set_user_defaults key "BTTDisableSecureInputTypeWarning" numberValue 1' line in terminal to disable this, but nothing has changed.
Thanks
MAC M1
MACOS 27.0.1 (26A434)
Version: 6.884
