Screenshot upload to Imgur problems after latest update
After today's (Apr 19, 20202) BTT 3.362 update on Catalina 10.15.4 , screenshot uploads to Imgur aren't working.
When selecting the area and uploading, the following message windows appear:
Imgur Upload Failed
Error Domain=NSURLErrorDomain Code=-999 "cancelled" UserInfo={NSErrorFailingURLStringKey=https://imgur-apiv3.p.mashape.com/3/image, NSErrorFailingURLKey=https://imgur-apiv3.p.mashape.com/3/image, _NSURLErrorRelatedURLSessionTaskErrorKey=(
    "LocalUploadTask <6CA75580-D7D7-4FD7-9DFD-B1F80730BC40>.<1>"
), _NSURLErrorFailingURLSessionTaskErrorKey=LocalUploadTask <6CA75580-D7D7-4FD7-9DFD-B1F80730BC40>.<1>, NSLocalizedDescription=cancelled}
I tried re-authorizing Imgur but it didn't work.
Any solutions?
The Imgur API seems to be down (their HTTPS certificate seems to have expired). I think it should work again as soon as they fix this.
Alternatively you could configure your own ftp server as upload destination
I think there's another issue as it may possible that their commercial API endpoint moved on to other URL.
If you check their status page which says All Systems Operational and you hover over "Commercial API", the tooltip displays one endpoint URL:
But when you go over to their API documentation, there's another Commercial API endpoint URL:
Could it be possible that they made this change without letting API users know?
Yes you are right, unfortunately I didn't get a notification about this.
I have pushed a new BTT build with the new API endpoint! You can get it by checking for updates.
Wow! That was quick :smile:
Thanks, I'll check it out.
Yep, works. Thx a ton!
