When I screenshot multiple times in a raw(10+) with CMD+CONTROL+SHIFT+4
When I'm on the 5th screenshot it doesn’t show in the BTT’s clipboard window anymore. After trying the 3rd or 4th time then it fixes it self.
what could be the reason?
how fast after each other are you taking these screenshots?
about 5 seconds apart, but regardless though. apples system handles clipboard every second.
I think BTT’s clipboard needs a bit of optimization to keep up with fast screenshots
5 seconds are more than enough - BTT by default checks every 0.5 seconds for changes.
I just tested here, but was able to copy tons of screenshots without issue. How big are these screenshots you are taking?
would say 70% of the screen. 13.5” screen.
also I think average between screenshot is 2 seconds
The screenshots are all different, correct?
I could only imagine the duplicate detection failing, possibly check whether turning that off helps:
