The new pre-defined action is working fantastically, however it does not seem to work on adobe applications correctly. The apps do not seem to be affected at all, they will not restore size or position.
All inputs, one action
- Type of Mac: MacBook Pro
- macOS version: 10.13.6
- BetterTouchTool version: 2.712
