Hello. I'm considering purchasing a remote control from Satechi (Satechi R2 Bluetooth Multimedia Remote Control) with the main objective of remapping its keys for shortcuts in BTT.
Can anyone tell me if it would be compatible?
Thank you.
Thank you.
BTT only supports the Siri Remote, have a look at the Remote Buddy app for more remote support
I was able to get a Kensington presentation remote working through BTT using BTT's Generic Device facility. It's not entirely easy to do this with a new device, but there are enough examples that you can figure it out.
(I think it mine a " Presenter Expert" model, but I expect the other models would work also)
