Hi. I do have a SATECHI BLUETOOTH MULTI-MEDIA REMOTE and I want to use with the BTT, unfortunately I don't know how to do so! My remote it is paired with the MacBookPro and I do installed the latest stable version of the BTT but it is quite confusing the setup. I can't find a proper way to add this remote to BTT so please help if possible. Thank you.
BTT doesn’t have support for remotes (only the Apple remotes.). Maybe have a look at the Remote Buddy app:
https://www.iospirit.com/
