Same Swipe, Different Trigger
To perform a two-finger swipe up or down, most people probably use their index and middle fingers, with a gap of about 1 cm between them.
Is it possible with BTT to trigger something else if the fingers are, say, significantly farther apart, perhaps 3 cm?
Edit: So the swipe would perform a different action if it were done with the index finger and ring finger, because those fingers are significantly farther apart.
In 6.635 I have added a new variable to advanced trigger conditions:
leftmost_rightmost_touch_distance_percent
You can use that to require specific finger spreads (it always is the distance between the leftmost and righmost touching finger)
