I'm constantly using the text transformation tools for my work (highlight text -> R-click -> Transform -> make upper/lower case or capitalize). Would love to bind these commands to option-u, option-l, option-c. Is there a way to reference these commands within BTT so I can bind to a keystroke? Thanks in advance
In system preferences > keyboard you can create a key command for those
If you like text transformation, also have a look at BTT's capabilities (which work in all apps) here: http://docs.bettertouchtool.net/docs/8c_text_transformer_functions.html
Using the predefined action " Transform Selected Text With JavaScript" is pretty straight forward.
