Safari Extension
Safari extension does not appear in Safari>Extensions. Is it because I am running the non-app store alpha?
Clicking Open Safari Settings causes the "Needs Setup" to change to "Could not open"
I am experiencing the same issue
Same here. Even with "allow unsigned extensions" ticked on it doesn't appear at all.
Same here, I am on the stable version
I'll look into this soon! Could be some signing issue.
Same here! On 6.609 MacOS 26.4 (in case it helps your development) :slight_smile:
Experiencing this running BTT 6.629 (2026070902) on MacOS 26.5.1 (25F80).
what this extension supposed to be doing?
it speeds up various things like the active_website_url variable retrieval or the predefined action to execute javascript in the browser
I am also experiencing the same issue on BTT version 6.735. I am on Sequoia 15.7.9 with Safari 26.6.
still having same issue with most recent BTT & Safari?
I think I might have found a code signing related issue, this should be resolved in 6.744! (uploading now)
