Running Trigger status
@Andreas_Hegenberg is there a way to show the status of running triggers/actions. In Keyboard Maestro there is a animated status menu icon and under this menu a Cancel item which shows the current running macro's.
No, that is not possible by default. You could create a menu bar status item and update it on action sequence start and end, but this is not built in. (You could also show a HUD on action sequence start and hide it on action sequence end)
