Running same app on different versions
Hi. I am running two versions of iTerm and BTT detects both as separate items when showing the dropdown to add apps (see screnshot). However, when I click the add button, nothing happens. Only the pre-existing app entry shows (one of the versions). Does that mean the shortcuts apply to both versions? Is it not possible to have different shortcuts for each?
they probably use the same identifier. In that case you can create a conditional activation group based on the executable path
