Been using bettertouchtool for over a year, i love the app, but im not sure i can use it anymore...
i cant play games while its running because of the annoying gittery mouse bug (happening when you hold down left click and move the mouse) the fix is to disable btt, the thing is, i can disable it for certain apps, but the game i play the most isnt detected by btt, and cant even be placed by linking the app directory (it just shows up as a question mark).
im trying to play tModLoader, terraria is able to be disabled but tModLoader isnt showing, anyone know any fixes?
for games you often need to create a conditional activation group and see which attributes are available for matching, then you can disable BTT for that conditional activation group:
just did that but changed it to activate on apps called "dotnet" because that appears to be the name of tmodloader, wish i has known this sooner THANKS A LOT!
