The title says most of it - if BTT is open, scrolling right with 3rd party mice (I have two) doesn't work. Right-scrolling with my built in macbook touchpad does work. Scrolling in all other directions works on 3rd party mice, just not scrolling right. As long as BTT is open, right-ward scrolling won't work on 3rd party mice. As soon as you quit BTT, it works. I have checked my triggers / presets for anything related to scrolling that might be causing this, but I don't see anything.
3rd party mice.
N/A
Type of Mac: Macbook pro 2018
macOS version: big sur 11.6.2
BetterTouchTool version: 3.722
I have the latest version of BTT installed. I have tried rebooting and re-installing, neither helps.
Hi Andreas -
I have software installed for a logitech mouse. When I close / open that, behavior of other 3rd party mice doesn't change. Only when I launch / quit BTT.
Before I opened the ticket, I thought I checked all the devices (like my touchpad), however when you asked again just now, I went back and double-checked and found a device I don't use that had "scroll right" configured to do nothing. I must have added that trigger accidentally at some point and forgot. I deleted it and now everything is working. Sorry about that, and thx.
