Given my problems with hyper key (Problems with a "Sticky" hyper key - #22 by iandol) I switched over to use the right-control key solution as suggested by @Frank1 and @Andreas_Hegenberg. So I set my caps lock in System Prefs:
Then add the distinguishing command:
And to trigger Alfred on release of caps lock use a key sequence:
But recently, the left control bindings have been taking over the right control bindings. For example I use [right⌃][b] as a hyperkey to trigger a build action. But sometimes [right⌃][b] stops triggering the action and instead moves the cursor which is what [left⌃][b] does.
Anyone else that uses this hyperkey solution seeing this?
- Type of Mac: M2 macbook air
- macOS version: 15.2 Beta (24C5089c)
- BetterTouchTool version: 2024120403
