When the “Right-Click-to-Draw” feature is enabled, my mice will sometimes stop registering right-clicks entirely. After this happens, right-click only works again if I quit BTT, disable “Right-Click-to-Draw,” or restart the BTT application.
I've tested on versions 4.3x, 4.7x, and 5.308 (latest build), and they all encounter the same problem. Because this has gone on for so long, I have disabled the right click drawing feature for a long time.
However the problem does not occur on the older build many years ago - I've tested on 3.346 (and I believe all versions before that because I used to keep the software up-to-date) and no problem with it - I never had the problem until a year or two ago.
Also, when the bug triggers, it affects not only the external mouse (in my case, Logitech M585 & Logitech M590), but also the trackpad’s double-finger right-click simulation, indicating BTT may be blocking right-click events at a global input level.
Affected input device
All input devices with right-click feature (mice and trackpads)
Device information
- Type of Mac: iMac (27-inch Retina)
- OS version: MacOS Ventura 13.7.3
- BetterTouchTool version: 4.3x, 4.7x, 5.308 (issue present), 3.346 and before (no issue)
Additional information
Right-click input stops working after a short period of use of the Right-Click-to-Draw feature.
