I have BTT 3.596. For some reason, when I "right click" on my track pad by just doing a normal two finger click, the Application switcher appears. It is as if I pressed Command + Tab. If I fully quit BTT, then the problem goes away.
I do have a BTT Trackpad shortcut for application switcher, but it is 5 finger tap. I have 4 finger tap set to "command + Tab" as well. I have disabled both and the problem still persists no matter what application I am using.
My 2-finger gestures all have nothing to do with the application switcher. Anybody know what is going on?
Thank you, yes that was the problem. I haven't used a mouse in years, so I'm not sure why that was there - probably an old setting I had, although I don't know why I would have assigned "Rightclick" to "Application Switcher."
Is there a way to turn off auto-update with BTT? That will help me correlate updates with bugs that coincide with updates.
