I use force clicks for quick screenshots...
- 2 finger force click - shift command 3 - fullscreen screenshot
- 3 finger force click - shift command 4 spacebar - window screenshot
- 4 finger force click - shift command 4 - custom sized screenshot
I also have the 2 finger click action set to right-click (with the macOS right click setting disabled in the Settings app).
Problem
The built-in macOS right-click triggers as soon as the trackpad is pressed with 2 fingers. With the BTT version of right-click, the contextual menu doesn't appear until my fingers lift up from the trackpad. This would work fine in my case, but I'm noticing that this right-click behavior doesn't work when right-clicking on messages in the Messages app. It behaves everywhere else just fine. I sometimes need to use right-click in Messages to edit a sent message. The current workaround is to hold Ctrl and left click.
Question
Is this a bug, or am I simply doing something wrong? I tried switching the 2 finger click action in BTT to Ctrl + left click to see if this fixed it, but that didn't work and seemed to treat all clicks on my trackpad like a right-click, which made the contextual menu appear constantly.
Thanks for your help!
EDIT
BTT right-click does work when right-clicking on links, just not on text bubbles, neither sent nor received.
